Re: Aluminum Boats In Salt Water
There are only problems with metal boats in saltwater when they are left in the water and subjected to galvanic corrosion and electrolisis through improper zincification, dissimliar metals contacting water and improper electrical grounding. A boat removed from saltwater after each use, need only be washed down to reduce the corrosive effect of salt on the connectors and finish of the boat. Likewise your engine cooling system should be flushed after each use to extend the life of your motor.
