Aluminum brazing/welding
bbenkaz
Re: Aluminum brazing/welding
would it be recommended for structural joints? I am thinking of putting a small platform in an aluminum jonboat. I thought about using some alum angle I have and these rods instead of rivets? yes/no/maybe
Thanks
iwombat
Structurally it's great stuff. What you'll need to watch for is warping of your aluminum under the heat. If you've got thick stuff - no problem. Thin sheet, and it may warp and not come back.
iwombat
One more helpful hint.
For isolated pieces mapp gas works great. For something like a boat hull (aka giant heat sinc) you may need to go with a rosebud oxy/acetelyne tip. Dunno - never tried it with a hunk of aluminum as big as a boat. I'd pick a test spot and see if you can get the rods to go liquid in a reasonable amount of time.
JB
Hard to get a small spot hot enough to melt the brazing rod on a large heat sink without heating a large area with propane or even Mapp gas.
I have one of those little propane/oxygen torch sets (I use Mapp/oxygen) and it does a wonderful job, even on castings.
tommays
Well what ever it is, it is NOT welding and the MSDS shows a Melting point: of 717-737F which is not happening as fast as the video shows without a real torch
And just for fun you need to try and warm up a soda can BEFORE you buy it and you will see just how hard that is to do
The crazy glue man holds himself up with a Sq inch on his hardhat; we all know how well that works on a real repair
And yes thats .027 wall tubeing on the ends and .019 wall in the centers
And yes I do get paid to weld stuff and have tried many miracle products and the ones that work still require correct prep work and skill
Tommays
bbenkaz
I am somewhat skeptical of the product hence why I asked the question. A couple people have had luck with it so.......... I just wish I knew how to weld and then the problem would be solved.
Tommays
bbenkaz
I am somewhat skeptical of being able to use it on say a boat due to the heat sink capability of the boat itself. I just wish I knew how to weld and then the problem would be solved. Guess I will just have to rivet.
iwombat
I have some, i use it all the time. It works basically as advertised. Just never tried it with anything large.
bruceb58
How thick is the metal you are going to be welding?
The reason I ask is that for 1/4" aluminum, you would need a 250 amp TIG welder to weld it if you went that route. You will be having a tough time with a torch.
I suggest you pay someone to do the welding properly.
You can also ask your question at a welding site that I frequent.
http://www.weldingweb.com/
I do MIG and TIG welding as a hobby. Have not done aluminum yet. Aluminum is a lot harder to weld than steel or stainless.
Ayuh,.........I'm with Tommays on this 1........
I've been Mig Welding Aluminum for years,.....
That Super Welding Rod you're talking about is more of a Flowable Solder,+ Not a Welding Rod.....
I guess iwombat has had Better Luck with it than I have,..... But I Can't feature it'll be Usable for the task you're requiring of it.......
iwombat
I don't do anything close to 1/4". 3/16" may be the biggest I've ever tried. But you're not trying for penetration of the material either.
I use it for applications where brazing is appropriate, which as it happens is quite a lot. It's not anywhere close to welding, but there's very few projects using aluminum I work on that actually really need a proper weld. For that matter, you probably don't want to use pop rivets where you need a weld either.
I have a tig welder for steel that I use for automotive projects. To be honest, I suck at welding aluminum so I braze when I can.
More on topic, I did a test on a hidden corner of my 12' gamefisher with mapp gas last night, and it liquified just fine. I don't think I'd have any issues brazing 1/8" stock to it.
Plus, if it doesn't work out properly you can just fall back on using rivets.
dadgummit
I tig aluminum all the time with a fancy welder, but for what your doing that alumalloy stuff is perfect. make it stronger by doing a lap joint over the top instead of just butting it to the side.
tommays
I am sure it can do some things fine BUT when you watch THERE video it becomes a snakeoil show
There is a reason its not certifed by the AWS or anybody
Tommays
iwombat
Well, yes. It is a sales video after all. You need to watch it as such.
It's easy and convenient brazing and no more.
I'd equate it to Soldering,........
Brazing it Ain't............
if you are not sure about brazing it take it to a welder aluminum melts at 1100 degrees and it does not change color when it happens and anything stuctural i would weld rather than braze and i have been welding for 40 years
have a good day
phil
