Aluminum or cast iron heads?
34 ford
Hi,
On a 5.7 omc engine. Is it a bad idea to put aluminum heads on, or would cast iron be better?
Thanks for the help.
Re: Aluminum or cast iron heads?
Welcome to iBoats
if you have a heat exchanger - aluminum heads are fine.
if you do not have a heat exchangers, aluminum is ok in fresh water, however not salt water.
34 ford
Hi,
Thanks for the info. guys.
I run the boat in fresh water only. It hydrolocked on me , tore it down and the aluminum heads
had warped. So I will surface them and put back together.
I just thought aluminum heads were a bad idea for marine use.
if it hydrolocked, you sucked water thru the exhaust. either bad manifold/riser gaskets, or something else went awry.
Hi,
Ayuh,.... If it's got aluminum heads, What sorta Cam is in it,...
To Big of a cam, will lead to hydro-lockin'...
34 ford
Hi Guys,
Thanks for the feed back.
I have put new exhaust manifolds and risers with all new gaskets and new exhaust flappers.
It has to be hydrolocking because of the wraped heads.
The camshaft is just a stock small block hydraulic lifter cam.
HT32BSX115
Look at that cam carefully. If it's a "Stock" marine, "RV" or truck cam then you're ok. If it's something else, you may be seeing reversion.
