Silent Player
- Jun 3, 2009
- 4
I'm looking at getting a new aluminum prop. Is there a drastic difference between the $99 prop and the $140 prop? Same diameter, same pitch, etc.
Re: Prop question
Hello HWSiii,
Sorry for the delay in responding. My direction has changed since my last email. I ended up putting smart tabs on my boat (wow, these things are amazing).
I originally thought I would need a 4 blade to get out of the hole quicker and keep a lower on plane speed, but now I think a 3 blade will work fine.
I also put my Viper 14 1/4 X 19 stainless prop on my boat. With this and my smart tabs, I'm definitely over revving the engine at 5100 rpm, at 37 mph.
Do I need to go to a 21 pitch, 3 blade prop? Also, on average (rough guess), how much top speed do you gain from moving 2 degrees pitch?
Thanks for you help and guidance,
Michel
Quote:
Originally Posted by hwsiii
Michel, I think you are on the right track I just need a little more information. Give me the RPM and speed numbers from 2,500 RPM to WOT in increments of 250 RPM.
H
Quote:
Originally Posted by Silent Player
Hello,
I figured I'd send you a private email, since you seem to be the authority on prop questions. Here's the specs on my boat:
1)1990 Chaparral 2050SL
2) LOA: 20' 3", 8' beam, 3,000 lbs.
3) Max hp is 275 hp. I couldn't find recommended
4) Normally 2 adults and 25 gals fuel (47 gal cap)
5) 17 deadrise
6) 1989 OMC Cobra 4.3
7) 160hp with 1.68 ratio
8) Recommended WOT 4200-4800
9) It does have a hydrofoil on there (early model)
10) Current prop: Bombardier aluminum 14 1/4 X 19 3 blade.
11) WOT is 4900 rpm, 39 mph gps with 2 adults and 25 gal fuel.
12) At sea level
13) Tuned up last year: New cap & rotor, plugs and wires, and carb rebuilt this spring. Compression is good on all cylinders.
14) Prop on boat has been on for 2 full seasons. It has a few ding and nicks on the leading edge, and the ends are a little worn. No vibration.
Goal for new prop: Boat currently has good hole shot. I've read your posts, and I think my boat is probably under powered. I'd like to get a 4 blade aluminum to cruise at a lower RPM. However, I feel that I may be able to get a slightly higher WOT speed (the last 300 rpms feel like they are over spinning the prop).
I'm looking at getting a 4 blade aluminum Solas Amita. It's a 14 1/4 X 19.
Just looking for your opinion.
Thanks,
Michel
