nobrainsd
- Jul 19, 2008
- 230
Thank you to all who made suggestions regarding this installation. This aluminum tank fits in my custom bench/console assembly very nicely and leaves room for the 60lb AGM battery on the side. With the tank grounded to the negative battery terminal I don't have to pull the 10 gallon tank to fill at the gas station. I'm getting too old for that? All of my fixed weight is reasonably forward in the boat and is not taking up floor space. The aluminum tank holds almost as much as the plastic tank that filled the space entirely. It just has less headroom between the tank and the seat. I do have small footpad straps on the forward wood flooring so I can take my large plastic tank on extended expeditions. The aluminum tank is bolted to an aluminum plate that bolts into backing plates at the floors edge. The backing plates key into the side rails. The tank has a vent shut off valve and an antisiphon vent valve. It does vent into the interior of the boat, just like my plastic tank did. You can see the vent anti siphon valve protruding off the back edge of my console. By the way, I don't smoke... Note the cut out in the console, required by a mistake on my part. The tank filler could have been anywhere on the tank, but I made the decision to put the battery on the passenger side after the tank was ordered, oh well! Hmmm, What's next?
