"... there were some minor dings on my stainless steel prop. I checked the runout on the shaft to see if it was bent and it checked out okay, and then I installed an aluminum prop.....
Why on earth have you put an aluminium prop on???? If you think it will 'save' the drive if you hit something again.... WRONG!!! I have seen stainless steel props wrapped up like scrap paper and thought that the inside of the drive will look like a grenade has gone off, only to find then perfect inside... Conversely, I have seen ali props with a few scratches and the gears in the drive cracked and broken beyond belief...
This thing about ali props saving drives is the biggest load of BS I have ever heard!!! And I've heard plenty...
The damage to the internals of the drive on striking something is more in the lap of the gods than what prop you've got on....
Chris....... "
Ok, borrowed from another thread.
What say you all? I Chris right or not???
Randy
Chris....... "
Randy
