am i crazy
SpinnerBait_Nut
Re: am i crazy
Nope, not crazy.
I have been out where there is ice on the sides.:D
Ezrider_92356
Re: am i crazy
well its up to 28 degrees so im going putting on the long jons jeans a shirt sweat shirt and jacket and packing a couple extra pairs of socks in some plastic bags incase i get my feet wet launching the boat. hope i catch some fish
treedancer
Re: am i crazy
Don't forget the suntan lotion ,it just might get up to 30.:D
PW2
Re: am i crazy
And chains for the prop in case it snows
Esox
Re: am i crazy
Not at all! :D
JB
Re: am i crazy
Lmao @ Pw2 :) :)
Gary H NC
Re: am i crazy
Esox,I bet that was really fun cutting through the ice.Looks like it was snowing too....:D
SpinnerBait_Nut
Re: am i crazy
That ice looks kinda thin.
One local lake here it was froze pretty good one winter and I was after some trout.
Took the jon boat and removed the little merc off the back and started using a back and forth motion with said jon boat to break ice at the ramp enough to launch said jon boat and then put the little merc back on and would run up on the ice and wiggle back and forth till said ice would break and then move a little more and repeat said action till I got to open water.
Caught fish all day and ice was thin enough still when I returned to ramp to be able to load.
Had to break ice out of the rod eyes all day.
Man, that was a long time ago.
Esox
Re: am i crazy
Actually it was just slush on the surface as it was snowing. :D But it's not uncommon for me to break through ice. If it's not paper thin, just make sure to use a sledge hammer to bust up the shoreline before launching. It's rough on your lower unit, transducers and anything else attached to the transom if you don't.
I've done the rocking the boat thing to get through the ice too. That time I even thought I was crazy.
Most of my friends and family think I'm nuts to be in a boat when it's barely above 20deg out and water temps are in the low 30's. To me it's just about getting the most out of the open water season.
Ezrider_92356
Re: am i crazy
well im back time to take an afternoon nap and then go back to fish sundown cought 2 walleyes and a cat by the time i got on the watter it was in the low 30's a flat tire on the boat trailer slowed me down as well as scraping the frost off the windshild of the truck. the tire had gone flat and then come off the bead, all i have at home is a little 12 volt compressor that i could probably blow up a tire faster with my mouth than that thing. so i went to take the tire off and the rim would just spin and the lug nuts wouldent turn so i jacked up the tire a shot of eather to get it on the bead and then i was on my way.
Bob_VT
Re: am i crazy
Crazy no....
Dedicated...... yes;)
