Wotknot
- Aug 6, 2002
- 310
Hi guys. I've got an '01 Alpha Gen II. Yesterday I was draining the gear oil and noticed it was dribbling out so I stuck an air hose to the gear lube monitor hose and applied "light" pressure. Sure enough it finally spit something out and it drained on out. No water in the oil but it did act as though just a tiny bit had coagulated. But afterwards I noticed 2 holes in the lower half right above the cavitation plate and just below the 2 forward bolts that hold the 2 halves together. I've never noticed them before. So, in applying air did I blow some type of seals? Thanks in advance for any and all replies.
