alandchris
- Dec 25, 2007
- 106
hello gents.
i have 2 sets of battery cables - one set should be for the 9.9 engine that I don't have yet - the other set definitely powers all the accessories, such as the bow mount trolling motor, the 4 switches that power the bilge pump, livewll aerator pump and the nav/anchor lights.
Question ONE, does it make sense to have all of these to get power along with the trolling motor ? It would have to go on the deep cycle battery because of the trolling motor. I would have thought that everything except the trolling motor would hook to the starting battery so the engine could keep this starting/cranking battery charged ?
Question TWO, How can I test my ignition / 8 pin connector (to the motor) I don't have my 9.9 engine yet - I have the ignition and controls for a Mercury outboard - the year of my stuff is 2001/2002 - and it has an 8 pin connector along with two other wires off the 8 pin connector. I have a lighted 'tester' tool with a black and red wire - with alligator clips. I'm not sure how to check at the connector (which pins do what?)
ALso - like I said there are 2 extra wires coming out of the side of that 8 pin connector - what would they be for ? Tilt on the outboard ? The original motor was an 02 Merc 25 HP 4 stroke.
Thx for any advice/help
Al
Al
