Prairie Dog
- Jun 17, 2017
- 17
My motor is a 1982 90HP.
I'm looking at the throttle cable where is joins onto the motor. There is a long white plastic fitting that slides along a brass rod. When I operate the control lever at the front of the boat through its full range of motion, the white plastic fitting at the back only moves 5/8 of an inch along the brass rod. As a result, the throttle lever on the motor is not advancing a lot. Shouldn't my throttle cable be causing the white plastic fitting to move further?
