Re: AMP GAUGE
I've got to tell ya, I wouldn't hook one back up. Thats a lot of wire carrying a lot of power that isn't really doing any work but is offering up a great opportunity to screw up everything if it ever shorts out. A volt meter will tell you all you need to know if you watch it closley. When the engines not running it should read in the mid 12's or you've got a problem right from the get go, then if it rises up to above 13 or so when its running you know that if nothing else you aren't loosing any current, so the condition of the battery is at least as good as it was before you left. Also, a battery that is dieing will show greater shifts and much faster shifts in rates of charge when you are operating a lot of electronics and begin running the engine up and down the scale. If the needle remains relatively stable its usually a sign of a strong battery. In effect a good battery buffers the system from rapid gains or losses of voltage. Anyway, I think you can get along nicely with just a voltmeter.<br /><br />Thom
