TwoRivers
- Mar 10, 2010
- 344
Hello all,
Working on a 70hp Evinrude no spark on any cylinder situation.
E70TLCEM
Troubleshooting I get no ohm reading between the brown wires coming off the stator.
Also get zero DVA voltage when cranking.
I pulled the flywheel but to remove the stator it looks like I'd have to remove the female (pin E) black/yellow wire from the connector leading to the power pack?
Do I have to buy the special tools?
This is an old heavily used but very clean motor with the original stator and timer.
Is there another way?
Any suggestions appreciated.
thanks
rob
E70TLCEM
thanks
rob
