anchor on windy day
nightvision
Hi all,
A newbie question here. What is the proper way to anchor a 18 footer bowrider on a windy inland lake? Do you point the bow or stern into the wind? Do you need one or two anchors? If two anchors do you use one on port and the other on starboard?
Thanks.
LFK
Re: anchor on windy day
IIRC, bow towards the wind, and let off plenty of line so that the anchor can set.
bjcsc
Point into the wind, slow to a stop, begin to reverse as anchor is dropped. Keep reversing while scoping out to 4:1 minimum (5:1 is better). When scope is reached, stop reversing, cleat/tie off anchor line to bow, preferably to the bow eye. Reverse gently again and pull until tight, i.e. until you're no longer moving. If you are in a tight spot, i.e. lots of other boats, you can use a stern anchor to hold your position, if not one anchor from the bow will suffice. The easiest way to set a stern anchor is to set the bow the same as above, but scope out 8:1. Once it is set, shut down the engine, drop or throw the stern anchor straight back, then manually pull yourself toward the bow anchor while letting out line for the stern until you get back to 4or5:1. Tie the bow anchor line off, then tighten up the stern anchor line to suit you. All of this assumes you have a proper anchor for whatever type bottom you're anchoring in with at least 6' of chain on the bow anchor. When you're ready to go, turn your blower on, pull yourself back to the stern anchor while letting out the bow anchor line (the very end of which should be tied of to your boat at all times - if not, do not drop it). Pull the stern anchor, clean it off and put it away. I pull myself to the bow anchor, some power to it - your choice. If you power, make sure you run your blower before you start. Either way, get to it, pull it, clean it, stow it and you're off.
ziggy
i don't have to much to add.
do not tie the anchor line to the stern only. never have the stern into the wind while at anchor.
guess there are lots of ideas about scope. 7:1 is what i've heard recomended for general purpose. 4:1 in calm seas, up to 10:1 for heavy seas.....
consider having 2 anchors if possible. ya never know when 1 might get stuck and unretrievable.
consider the environment yer gonna be boatin in too. sheltered lakes won't be the same as big lakes or the ocean....
Texasmark
Didn't bother to read the replies.
ROT.....Rule of Thumb......NEVER put your ASS into the Wind........You may not live to it again.
Mark
Mark42
Like this...
Wind was from off shore, a bit from right as the photo was taken. Dropped main anchor (danforth style in about 5 foot of water, then idled in toward shore, killed motor, tilt up, jump out and tie anchor off to Mooring Bit on deck. Let out about 30 feet of line. Then tied off stern cleat to stake on shore. This is a bay, not a lake, at low tide. I plan to replace the stake with another danforth anchor.
b00tstrap
You weren't out last weekend were you? Some guy in the same cove as me must have dropped (straight down) his anchor 4 times before by chance the wind pushed him in the right (away from me) direction and the anchor set !!!
It was amusing watching him snap his head around and yap at his wife while he started th boat and re-positioned. LOL
Texasmark
Only problem with anchoring both is that if you are in open water and the wind shifts direction your arse can very well be into the wind.
With a single point anchor, you can swing 360 degrees, which is a large area if anchored properly in deep water, and somewhat undesirable, but your bow will always be facing the waves.
HTH,
Mark
Texasmark
Nice pic Mark. I like your method of "beaching" your boat.
I never could drive my boats up on the beach and scratch them up. I always anchored off shore as you are doing. A bit of a problem and I got wet every time I did it, but I figured it was worth it.
Your restoration sure looks sharp. I know you are proud of it. Your hand made MFG decal is clearly visable. d:)
Mark
Mark42
Thanks, Mark.
If I was anchoring farther from shore I would just do one anchor point and let it swing with the wind like you suggest. When I anchor so close to shore, even if the wind is from the beach, I anchor with two points to ensure the bow is always to the waves. My experience taught me that regardless of wind direction, in shallow water right near shore, it is best to have the bow facing the oncoming waves and leave the transom facing the beach. This prevents waves from braking over the transom and flooding the boat.
