Re: Angler boats - any good, issues?
dpski,<br />I think the 18' Angler, would be fine, for your needs. A 115Hp, would probably give you, somewhere around mid to upper forties top speed. My 1999 20'CC (built in Aug 98) has a composite transom, and wood stringers. Not exactly sure when they went to all composite. I believe it was sometime in 99. The only problems I had, with either of my Anglers, were air bubbles, or voids in the gelcoat(on the 18'- mainly on one side of the liner) and a few stress cracks, on the 20'.My 18' did have a problem with water, that got in to the transom, because they didn't caulk 2 thru-hulls. That was just a stupid mistake, on some riggers part. I wouldn't worry if that boat does have wood in the stringers, they had been making them like that for almost 30 years.These cosmetic problems, if any should be clear to see. Neither of my Anglers, had any problems with the hull.That 99 should have a lifetime limited hull warranty. I don't know, if it's transferable.<br />Hope this helps
