SeaEsta-12
- May 25, 2012
- 109
Hello all!
Need a little help/ clarification.
I have a boat that is only used in salt water and currently has zinc anodes. I will be moving the boat permanently to fresh water and need to change out my anodes to magnesium.
Here is where my question arises. The boat was originally purchased to be used in salt water, so when the previous owner bought it, he had a corrosion system from Volvo Penta installed. The boat has three locations for anodes (Drive, transom plate and hull plate)
For the life of me, i can NOT get the hull plate anode off. I dont think that anode has ever been replaced in the past 10 years. the Nuts are frozen on, and when I try to loosed them, the bolt is turning from the inside of the boat.
Would I be creating a mess if i just left that anode on? it seems pretty deteriorated already.
I will be in fresh water only, and from what I understand, the VP corrosion system is only used in salt and brackish water.
What are my options in this case? I plan on disconnecting the corrosion system from the battery. Good idea? No need to? or bad idea?
I have the older system. which looks like this.
Thank you all!
Thank you all!
