Hi All! I have a new to me 1998 Bayliner Capri with a 4.3l that I keep getting an alarm sounding beep beep beep beep........ I did my research a found the 3things that set the alarm off (IE: low gear lube, low oil pressure, high temp) disconnected all three one at a time and could not silence the alarm. The weird thing is it only does it in the water. On the trailer, on muffs no alarm. This boat has a stock depth gauge does it have a shallow water alarm that could be malfunctioning? Or do I have a short somewhere? Any ideas? Thanks!
