another alpha 1 oil leak at shift shaft
rochsner
Just purchased a 91 stingray with 4.3 litre alpha 1. I have an oil leak that looks like it is coming from the upper unit shift shaft. What seal or seals could cause this? I have just changed the driveshaft seal, impellar and impellar housing. This is my first boat so any pics, links to manuals, p/ns would be helpful. Boat shop is out of manual at this time. Do I need to remove the whole unit to change the shaft seals? Any help is appreciated. The good news is it is a new motor and runs good.:cool:
Re: another alpha 1 oil leak at shift shaft
Ayuh,......
Welcome Aboard,....
Manuals can be found Here,....
There are Several Seals that might be the issue,....
The manual will explain how to find which 1,+ how to fix it....
rochsner
Thanks for the info, much appreciated.
Don S
Do you have an Alpha I or an Alpha I Gen II drive?
91 was the first year of the Gen II drives, but boats may have older engine/drive packages installed depending on when the boat was built.
