I have an 87 Century with a Mercruiser I/O. When I made the deal 2 years ago, the owner had the shift cable, shift cable bellows and drive shaft bellows replaced at a cost of $650. However, he did not replace the water intake hose or the exhaust bellows. Last fall when I had the boat winterized I inquired about replacing the exhaust bellows and the intake hose and the mechanic said in doing so, he would also have to replace all of the other bellows as they were glued on. In searching the forum, it does not sound like the exhaust bellows is critical and mine is not currently leaking. What about the intake hose? The outer covering is cracked, but it does not leak. The mechanic claimed my boat would sink if either the exhaust bellows or intake hose broke. I don't believe that is the case for the exhaust bellows. Is that the case for the intake hose? Finally, can the intake hose replaced without removing the entire stern drive? If so is it a tough job for one who is mechanically inclined?
thanks!
thanks!
