I have a recently purchased '86 Johnson 28hp motor. I took it out once with no problem. Now, when I turn the key, the bendix gear just spins without raising up to engage the flywheel. The gear spins really fast. After reading a lot of posts from this EXCELLENT site, I thoroughly cleaned both ends of the battery terminals and the posts and made sure all connections were tight. Still no luck -- it just spins in place.
My question is precisely by what means does the bendix gear go up? I think that somehow the spinning force of the gear raises it, but I'm not sure. But I can't even get it to go up manually. I turn the gear by hand and put a bit of pressure from underneath, but it doesn't seem to go up. I put some WD-40 on the upper part of the shaft for a quick fix, but that didn't help either. Since it worked the first time I took it out, I wouldn't think that its up/down movement would be so seized up that I couldn't move it up manually.
Another bit of information: using my fingers the gear will freely spin both directions. The starter turns the gear counter-clockwise in order to turn the flywheel clockwise.
I was going to take the nut off the top, to see what was going on, but it wasn't going to come off easily so I didn't mess with it.
