Another bilge problem
bearcat81
Started working on my 1996 Skeeter; which has a 120 hp Force motor on it. Trying to get it ready for the lake and found the the bilge pump is in a continuous run mode even with the switch off. I know this does not have an automatic float to shut the pump off. I have a 360 Rule bilge pump. Need some guidance as to what can be causing this problem and how to resolve it. Appreciate any feedback.
Re: Another bilge problem
Ayuh,....
Follow the Wires,+ See where they Go......
At this point,.... It sounds like the Switch is Broken.....
bearcat81
Still confused, I traced traced both sets of wires running to live well and bilge pump diconnected both pumps set them one at a time seems that both switches work on both pumps , but I found other set wires one reads WD on one of the wires I disconnected the wire and the humming stops is there other pump or device that I missed ?
Coors
Start at hot wire; wire both switches to it, hot to hot.
Then figure out where the mis-wiring is.
Sounds like someone wired both switches together, in parallel. so one switch feeds both, even if one is off.
bearcat81
Both switches will turn the bilge pumps off and on, but I can still hear something running and can't tell what it is. I checked it by turning on each pump individually, I can physically feel them working, but when I attach the third set of wires on, something else kicks on; just can't see or tell what it is; this is what runs continually even when both switches are off (live well and bilge pump)
SS MAYFLOAT
Could it be your blower for the bilge that you hear running?
Coors
Yeah, just start touching everything until you feel vibration.
bearcat81
I'm still tracining the the wires seems the vibration is coming just underneath the gas tank is that common? sure hate to take the gas tank off.
