I have yet another foam question for you all. I plan on using exandable foam and was trying to figure how much I would need. The weight rating on my boat is 1050 lbs. It is a 15' 1968 Chrysler Del Ray, all aluminum. I am not sure of its weight. When adding foam, do I need to add enough to offset the weight rating on the boat, or how should I go about this? The motor alone is 195lbs, does the aluminum offer any self flotation, or will I need to compensate for it? Also, there are no stringers in the boat, the floor is attached to wood that is attached to the cap. Will 2lb be enough density to walk on under plywood or should I go for atleast 4lb? Thanks for all the help!
Brent
Brent
