Another Force noob question......lower unit lube?
Cannondale
'90 Force 50hp.
What's the recommended lube/oil to use in the lower unit?
Want to change it tomorrow and need to make sure I buy the right weight/stuff.
Thanks from the Force n00b.
roscoe
Re: Another Force noob question......lower unit lube?
Any marine grade gearcase lube will do.
They are all the same grade, unless you go synthetic, or get the "Mercury high performance" lube recommended for I/O's.
Cannondale
Great! Thanks!
emoney
Like, Roscoe said. Any 90 weight lower unit lube should fit the bill.
