Hope all are enjoying this 4th of July!
Engine temp alarm pegged out (220) this morning which caused alarm to constantly beep. Immediately shut down & sat for 15 minutes or so until temp gauge read 180. After spending another 5 minutes to get it to crank, I headed for the boat ramp at about half WOT (RPM gauge decided to stop working this morning as well). Within minutes, I was 220 with alarm going off again. Shut it down again and used trolling motor rest of the way.
At idle, water pressure was around 3#. Up on plane when the alarm went off, my water pressure was around 10#. Tell-tale stream was shooting out entire time.
Get it home this afternoon on muffs, tell-tale takes roughly 20-30 seconds to shoot out after cranking up (which it always has) but the tell-tale water is almost scalding hot. Temp only reached around 160 which I assume because was only fired up for 60 second or so before I shut off.
Temp reached 200 last weekend as I was heading in to load up. Had just fished over some underwater vegetation/ moss. Even though my outboard was up as I trolled through, I could have possibly sucked in something when I headed for the ramp. If so, where would I even start to take things apart to check? Both thermostats? A water "filter"? The impeller? Poppet valve?
I know there are several threads regarding this issue, just hoping someone has come across the exact situation with a close enough outboard type to possibly help me out. It is a 1986 Mercury 150 HP Blackmax V6, 2-stroke.
