Hey Folks. Been trolling through the forums the last coupe of days. Finally decided to register and throw my question your way. I have read enough of the Prop type questions that hopefully I can answer most pre-req info. That said however I am missing some RPM info to make this truly an educated prop decision. Just trying to find a starting point for the season that I can build upon.
1) Performance issue you are trying to correct.
- Current composite prop is broken, and stainless has some nicks. Want a new Composite or Aluminum and keep the Stainless as a backup. Liked the performance of the Stainless though.
2) Current prop manufacturer, model, aluminum or stainless as a minimum.
- 13 Spline
- Stainless - OEM Part Number - 389510 3 blade - 13" x 19 Pitch
- Composite - No Part Number - Made by ComProp - 4 blade 13.5" x 15 Pitch
3) Current prop diameter and pitch (required).
- See above
4) Wide open throttle RPM and speed with an average load (very helpful)
- Not sure.. Boat is back in the water in about a month. Just looking for a starting prop.......
- Remember being up around 4300RPM at WOT but this is just a guess. This would be on the Composite Prop if I am right.
5) Engine/drive make, model, year, and HP
- OMC 3l, believe the engine is an 1988 (boat is an 1989)
- Based on what I am reading on the wonderful internets its 130 or 140HP
6) Boat make model, year, length and weight
- 1989 Marvac 17' - Bowrider
- Not sure about weight
- 4 People around 470lbs almost always in the boat
- No much gear, 4 or 5 fishing rods live in the boat and some light gear. No much else.
- No Kickers, trolling motors etc and only one battery for the motor
So adding a little to this....
Young family Mom, Dad and kids 5 and 7.
I am new to boating. I bought the boat Late 2011 season used not really knowing what I was getting into. Well other then falling in love with being in the water it has also sucked up some money fixing things up. Might be in the market for a new boat in the next couple of years but for now I need to make the best of the ol'Marvac.
Usage is general run about with the family. Some day trips through life locks, a little tubing, some fishing. Not a big fan of going fast so just want to keep things running well with out any unneeded engine stress.
We are on Upper Buckhorn Lake in Ontario. It is a shallow lake that gets quite weedy. I have bounced off the bottom a few times now trying to get to a few fishing spots. The last time was just before we pulled the boat out of the water for the winter and I damaged the Composite prop.
I put the stainless prop on at this time and loved the performance of it. Lower RPM at reasonable speeds and despite what I am reading seemed to sit on plain a little easier at low RPM as well.
Long story. I guess the only other thing to add here is what I think I am looking for. Again I am new to boating and don't claim any knowledge of my own, just what I have read the last couple days trying to sort this out.
Would love to just leave the stainless on, but as I have had some prop strikes in the last couple years and project it will happen again I think I should be going with something softer to protect the lower unit. Not sure if I should track down another Composite or go Aluminum. Hub System or no Hub system, what pitch would be a good starting point? Brand, suggested company to order from?
Sorry for the overly long post. I know I don't have all the answers to make the most informed decision but I hope to do the best I can with what I have. This season will be attacked with a lot more understanding of props so I will try and track some data....
Thanks!
Mike
Edit
If it helps I can post pics of the boat and/or props as well.
- 13 Spline
- See above
Thanks!
Mike
Edit
