Another ohm question
f_inscreenname
Did the test to check the coil's resistance. Pertronix says that it has to be 1.5 or greater. When I did the test I came up with 1.6 and it would momentary jump to 1.7 every now and then. Is the ohm scale like the rector scale (a couple of decimal points greater means a big difference) or am I boarder line and should add a ballets resistor to be on the safe side?
JB
Re: Another ohm question
Howdy, FSN.<br /><br />You are fine. 1.6 is greater than 1.5, like the book says.<br /><br />Analog Ohmmeters are logarithmic, like the Richter scale, but digitals are just. . . um.. . digital. :)
