BoatDestroyer
- Aug 1, 2004
- 7
i'm sure everyone gets tired of reading about overheating problems. <br />but anyway , this one has me stumped. <br />first , she's a 1986 mercruiser 350-260 <br />i've pulled both manifolds and checked and they look like new , no rust or corrosion , new impellor and housing , new belts , pulled all hoses and checked for obstruction , i'm baffled<br /><br />ok , now the problem , i put her in the water , and she runs fine , idles at 800 and the temp stays at 135-140 , as soon as i get on plane the temp starts going up past 170-180 , and i drop off plane and the temp goes back down , if i rev it up in neutral , 2500-3500 r's , the temp drops FAST , it seems because of that the manifolds are flowing e-nuff water , the circulating pump is turning , water is flowing from the exhaust (hose fed) , i have great pressure at the water pump from the drive ( took hose off water pump ) <br />the only flaw that i can see is that i need the lower unit re-sealed , i have water mixing with gear oil , but i dont see how that effects the engine. <br />thanks in advance
