bumblebeeamigo
- Mar 11, 2010
- 51
I've spent too much time researching this and I'm going mad!
So if I can summarize it with some generalizations:
Every pitch decrease raises 200 RPM
Moving from Aluminum to Stainless drops 200-300 RPM
Moving from 3 to 4 blades drops 400 RPM
Suggested full throttle RPM is 4800, true redline is 5400
So that would mean if I am seeing 4800 RPM with a 3 blade Aluminum, and I wanted to plane faster and didn't care about top speed, I should:
Go to 4 blade stainless (minus 600 RPM) and drop the pitch 3" (Plus 600) to stay the same.
If I want to push the motor, I could do the same and drop the pitch 6" and I'd be pushing it.
Therefore in Summary, if my current blade is a 23" pitch Aluminum, I'd want a 19-21p 4 blade stainless.
I do understand cupping matters, blade size matters, and design matters, but I have to start somewhere. I also know this is debated in depth and the right answer is "try a million until you find the one that works for you", but I need a starting point
Thanks much!
Thanks much!
