Please note that the PICTURE UPLOAD function is not working. The iBoats Forum Moderators are working with the system administration folks at the parent company to get the issue resolved. This happened about a year ago and here we are again. In the meantime you can post photos as links to a picture hosting site of your choice. We are sorry about the inconvenience and will advise when the issue is resolved. Thank you for your patience.
i have a 19.5ft tahoe deck boat with 4.3 mercruiser bravo 1 outdrive. dry weight is around 3000lb. it has stock prop. want to know what a good prop would be for all around use. lots of cruising, fishing, and some tubing.
To give you the best advice we need to know prop size(usually on the barrel or under the prop nut);present max rpm and speed.(GPS is best)and the max recommended rpm range.(usually a label on the motor).
