Another prop question
jstamatov
I have Wellfoot 18 Classic that I mostly use for pulling kids on the tube and wakeboarding. It's got a 4.3L OMC with the holly 4brl carb and a few other minor engine enhancements. My guess is that it's probably around 200hp. At WOT, with the engine trimmed up a little to refine the plan, it hits 4400 rpm with a 14-1/2 X 19 prop.<br /><br />From all of the reading I do on this forum, I gather that's about perfect. But, we wakeboard in a lake with very low water, and despite lots of caution and inexperience (i've been boating only two years), I seem to keep dinging the props. My question:<br /><br />1) My two alum. props are dinged and need to be repaired. Would I be better off repairing the better one and using as a back up and buying a four blade composite with the replaceable blades?<br /><br />2) The boat is very heavy, and it does seem to take long to plane (it seems the tube creates more drag than anything else). When towing, it always seems to lose its plane around turns, etc. Would I be better served going to a lower pitched prop or should I stick with same setup?<br /><br />3) Repair both props and scrap the composite prop idea?<br /><br />Thanks in advance - this is a great forum.<br /><br />3) If go to the composite, is the 4 blade the best? I read many conflict posts on this topic.
WillyBWright
Re: Another prop question
Forget the ComProp. You're going to break it. Pirannah Prop with the replaceable blades is an option. Haven't seen much about them lately. Still out there?<br /><br />I'd suggest a 4-blade aluminum Alpha prop, 18 pitch. Good for pulling, and it lifts the stern. Sould be a better shallow water prop than just about anything out there.<br /><br />And repair at least one of those 19s.
Rebuild Both of your props,<br />And Add Smart Tabs............
walleyehed
If ya got the cash, go with Smart-tabs AND the 4-Blade in 18".....that would be a great set-up.<br />Still, it would be best to repair one of the 19's for a spare-Always carry a spare....
BillP
How much is it to repair the alum prop? My personal experience has shown buying a new alum prop is close to or less cost than rebuilding alum. Ebay has omc alum prop real cheap.
Chris1956
I think the answer is in what type of bottom the lake has. Soft mud and silt will tear up an aluminum prop, but will not damage a SS prop (or lower unit). Where I boat (shallow, mud, silt) I would go though at least one aluminum prop per season with my 19' bowrider. I have been using a SS prop for five years, and it is still undamaged.
