I want to re-seal my upper and intermidiate as well as ther lower gearcases in my 1985 OMC stringer 400. Can I get away with using the old shims if I don't replace the ball gears or any gears and bearings? just replacing seals and gaskets... thanks
Be careful that you don't bend or damage them in any way & when you tighten bolts use the proper torques so you don't distort the shims and they should be fine.
