Fishermark
- Oct 19, 2003
- 5,617
I finally got my entire engine and transom assembly out, (found some soft spots in the transom... that's another project!), and I notice that the rubber o-ring in the gimbal housing I removed is a one piece rubber gasket. The seal I purchased is a softer foam rubber gasket that is one long piece - like a circle that someone cut. It is a GLM part # 86712. <br /><br />A couple questions...<br />1) Is this a good gasket? Are they all a "foam rubber" type verses a more "conventional" rubber o-ring seal?<br /><br />2) I bought the seal here. It shows a picture of a seal that is a circle, not one that has been cut. Is this supposed to be a circle, and perhaps mine has been either cut or pulled apart?<br /><br />Any help would be appreciated.<br /><br />(Keep watching for questions about the transom repair!
) <br /><br />Oh yeah, this is for an Alpha 1, gen 1 gimbal housing.
