Another question Snapperbait
snapperbait
Re: Another question Snapperbait
You got it right... Thats what ya need... ;) <br /><br />There might be three bolts you need that I don't see in the picture to mount the helm to the bracket, but there ez to find at any hardware store.. Use Grade 8 bolts only.. ;)
D
DJ
Guest
Nathan,<br /><br />It depends on you console. You should have some kind of bezel now. Make a comparison.<br /><br />The 20 degree will allow you to position the wheel up high or down low. The 90 will make it come straight out at the same angle as the face of your console.<br /><br />If you want to get real fancy, get a tilt helm. The cables are the same.
NathanY
Well I ordered that one off iboats, if it does not work can I send it back?
