another setup ?
astro1
1988 Astroglass 166v 17' bass boat.1988 90hp v4 vro.I need to try to figure out where to start with this. <br />It came with a hydrofoil (not hydrofoil brand) a 15"x13 3/4 alum. prop,a 17"x13 3/4 alum prop and a 19x13 stainless prop. Old owner said he put the 15 on it for the hole shot. is it worth putting a 4" spacer or jack plate on the moter and any Ideas what prop to start out with? or any other ideas.<br />Thanks
astro1
Re: another setup ?
a Little more info. It does have power tilt/trim I took it for a short test drive (to cold to stay out long) It had a great hole shot.tach seemes wrong I will check or replace it. speedomiter way off.It showes about 4000 rpm wide open with 15" prop (my hat would not stay on wearing it backwards)
Dhadley
Re: another setup ?
Welcome!!<br /><br />Ah, the 4 positions of a bass boater's hat-- <br /><br />Off (in hand, not on head)<br />On (on head, bill forward)<br />Lock (bill to the side)<br />Race (bill pointed back)<br /><br />OK, to your questions. Youre absolutely correct. Lets get the tach issue straightened out first. The tach and water pressure gauge are our most important allies in this venture. Along with an accurate way to measure speed. GPS is preferred.<br /><br />Once we get the tach fixed we can establish your baseline slip %. We'll go from there.<br /><br />My guess is that at least some of your props are aluminum. That's OK. We just need to know what brand -- OMC I'd guess. <br /><br />I'd also guess that eventually we'll benifit from a jackplate. But let's not worry about that now.
astro1
Re: another setup ?
Thanks<br />It may take a little while(it is suposed to snow this weekend).water presure gauge is on the way.<br />I cannot tell what brand the props are the 15" alum. part# is 391198 and the17" alum.has a (est) and part# 391199. The 19"is a stainless and I dont have a part# off of it yet but it has a black pouder coat finish and it also has alot more cup than both of the aluminum props.
walleyehed
Re: another setup ?
Both alums are OMC as Dhadley suggested...he doesn't miss very often.<br />The 17 pitch should be 13-1/4" (391199).<br />I'm just here to watch, so continue on!!!
Dhadley
Re: another setup ?
Just here to watch, huh? You just contributed so there goes your Peeping Tom theory..... :D <br /><br />Anyway, it sounds like the ss prop is an OMC prop too. Thats good. Keep us posted on your testing.<br /><br />Snow, huh? Well, good luck with that. I can't decide whether to go boating or to Daytona (Bud Shootout) or to the dragboat race this weekend. <br /><br />Let's see....the race boat isn't done, I can watch the Shootout on the widescreen (and the BBQ is right outside) and the Hydra Sport is ready. I guess it's working on the Hydrostream Sat morning, the Shootout Saturday night and fishing on Sunday.
astro1
Re: another setup ?
Hi you were right about the 13 1/4 X 17 . I still cannot read the part # on the 19" stainless.We only have about 8" of snow so far.I may have to get brave soon. and go out anyway, it is soposed to be windy and in the 20's sunday..(I may wait a week or two.)I will get back as soon as I can.<br />Thanks
Dhadley
Re: another setup ?
Sounds good. From what we're hearing on TV you guys are getting slammed with snow today (Sunday) anyway. <br /><br />Stay warm!
astro1
Re: another setup ?
Well Water preasure gauge came in yesterday,and 2" of snow. It is up to 10 degree's so far today and my boat trailer is the same width as my garage door. I am ready for summer!!!
gatorred
Re: another setup ?
Ah, the 4 positions of a bass boater's hat mine is 5 sit on it but it get's smuched<br /><br />I lost my hat in lake it sank quick my helper that day was no show
Texasmark
Re: another setup ?
I was out the other day and lost mine too but was able to capture it. But it was soaked and couldn't be worn.<br /><br />Moral of the story; take 2 on a wintery day so that WHEN you loose the first one, you have a second to protect your head till you can get back to the dock. Grin<br /><br />Or use a jacket with a hood and cover the cap so that it can't blow off......but then there is the problem of watering eyes to the point where you can't see....Ah goggles, but I keep forgetting them.<br /><br />Mark
astro1
Re: another setup ?
Ok I got brave and it got up to 30 degree's.<br />Ok to begin with I raised the moter up 1.5" and put the 19 pitch prop on.I think the part # on it is 389510 (verry hard to make out)The hole shot is kind of slow about 15 seconds,water preasure at idle about 2 lbs. at wide open the water preasure is 13-14 lbs trimed out and the tach is showing 5000 rpm speedomiter is showing 35mph. I can trim the moter up alot more with it set this way about 3/4 going by my gauge (when it showes level it is up just a little)I have about a 2-3'rooster tail now No gps yet..<br />What should I try next..Thanks
astro1
Re: another setup ?
I decided to put on a new water pump next. <br />I was woundering if the MW Rapture 13 1/4 x17 prop would be good to try on it.
astro1
Re: another setup ?
Ok took off work today. 60 degrees outside.<br />I ran the boat today with Gps my results were 4200 rpm. wide open 32 mph gps and water preasure was 14 psi. 19 pitch stainless prop and moter raised up to 3rd hole.
astro1
Re: another setup ?
Today I put on the 15" pitch prop. boat ran 5200 rpm 31 mph with engine trimed almost all the way down. as soon as I start trimming up the boat would start porposing bad, if I tried to trim up anymore the prop would blow out. water preasure was about 12-14 psi.
