Sorry guys, I searched the site, read previous relevent threads, but still have a question. 1989 OMC 4.3l.<br /><br />My symptoms are allmost exactly like those in the "4.3.lx starter clicking????" thread. (Click when I turn the key, after doing it a couple of tiimes it will start). <br /><br />As per previous suggestions, I sanded and cleaned all of the battery, solenoid, and slave soledoind terminals.<br /><br />I then used the method suggested by Don to check the slave solenoid. Hooked up test light to one of the large posts on the slave (live). Hooked up the test light to the other large post (dead until I hit the starter). When I hit the starter, not only did the light fire up, but it started every time. When I took the test light off and tried to start, same problem as at the beginning.<br /><br />Just me in the boat, so i needed to rig the test light so I could see it while at the console to turn the key. I clipped the positive lead to the slave post and ran a wire from the negative lead and clamped it to main ground screw (the one for the starter, etc.)<br /><br />So I'm wondering if the difference is that there's a problem with the ground at the slave solenoid; maybe I bridged it when I hooked the negative test light lead to the main grounding screw and thats why I had no problem starting?<br /><br />I was looking at the Clymer's wiring diagram and realized that I don't know how the slave is grounded. Is it grounded just by how it's connected to the motor instead of with any wires? If so, might I stand a good chance of solving the problem if I take the entire slave off and clean up the bolts and contact area?<br /><br />I'm winging it, trying to deduce some things I have little knowledge about, so go easy on me, lol.<br /><br />Thanks for input.
