Can anyone tell me on a Chevy V-6 (OMC)..does the coolant circulating thru the engine circulate upwards out of the thermostat housing or downwards into the thermostat housing? We are installing new manifolds on a closed system and I am not sure which way to hook up the coolant lines to the manifolds. I know to hook the feed line on the low side and the exit line on the high side of the manifold but not sure whether the feed line comes from the thermostat housing or from the heat exchanger.
Thanks
Thanks
