Hello, hope you all can help,
I have a 2007 Mercury 220M 5.0L, S/N 0W665765, installed in a 2007 Bayliner 215 BR. Approx 45 hours on the engine and boat since new.
I had no problems with the boat since I purchased it from the original owner two months and 10 hrs ago. The last trip out the engine lost power and stopped in the middle of the lake. Had to get towed into shore. No spark. Inspected the distributor, it had corroded contacts so I replaced the cap and rotor. Still not spark. Replaced the sensor in the distributor, no change. Also replaced the coil with no change.
I have used the Thunderbolt V troubleshooting chart and have several questions.
1. I have checked the tach Gray wire and found 3.5 ohms of resistance at the tach. Disconnect the engine wiring harness at the engine the problem goes away (not a boat wiring problem). Reconnect the harness the problem reappears. Disconnect the negative wire from the ignition coil the problem goes way (both new and old coils). Does this count as a short, by definition its high resistance not a short? (FYI when I open the kill switch the 3.5 ohms goes away with all wires connected)
2. I do not have 12 volts at the positive terminal of the coil, I get 9-10 volts unless I disconnect the wire from the coil then battery voltage, 12 volts. (both new and old coils).
3. Checking the voltage from the module I also get 9-10 volts unless the coil is disconnected then its battery, 12 volts.
4. I have done the "tap" test with no spark produced.
It sure seems to me that I have to spend the $400 for a module based on the chart but the questions above make me question purchasing it. Any help would be greatly appreciated.
Thanks
Thanks
