okay guys.. Hoping you all can help me out. I started a thread in the props section but it turned out it wasn't a prop issue. I wanted to start a new thread in the proper section so here I am. I am having a rpms issue. I couldn't get over 4000rpms @29 mps with a 19* prop. I checked my compression today to rule that out. compression was great 150 155 160 160 so My next step was timing. I put it in base timing mode which as soon as I jumped the wires from the switch the motor died. I did it a few times to me if maybe it was a user error but it still did the same thing. After a bit of research I came across a thread where someone was having a similar issue because his time was so far off. So what I di was start and have the engine idle and adjusted timing to 12* BTDC. I was able to get it to 10*BTDC because the wiring harness coming out of the distributor was hitting the hose that went to the power steering pump. As soon as I set it I put it in base timing mode which now the engine stayed on which was great. The timing was set at 2*ATDC . I then read to throttle up to 2800rpms and check to see if the timing went up to 28*BTDC but when I reved up it went to 12* BTDC. Am I doing something wronge? How do you even read 28* BTDC if the tab only goes up to 12? Am I supposed top be adjusting it on the ATDC at idle to 12* then when I throttle up it goes to 12* BTDC which would add up to 24* increase? As you can tell Im a bit confused... well to be honest.. a lot.
