Hi, I recently acquired a 17' crestliner that is in good shape but the transom is spongy around the motor mounts so it has to be replaced. I am not sure if i will use sea cast or new plywood and epoxy yet but either way I'm going to get all the wood out not just the rot. My question is instead of removing the whole top of the boat I plan on cutting each side about a foot up and just removing the rear section. Then i will repair where I make the cuts at when i put it back together as i am not worried about it looking like it is fresh from the factory. it is a 1975 btw. Is there any reasons why this wont work and has anyone done it this way before? Thanks,<br /><br />Rich
