Another trim tilt issue
greenoil
Hi all,
I have a 89 force 85hp on a 17ft bluefin aluminum bass and ski. It has electric over hydraulic trim tilt. The problem is that the middle cylinder looks like it may have been over extended or something. The two smaller outer trim cylinders dont lift the engine and it sounds like there is air in it. I tried taking the cap off and lifting it all the way 4 times like the owner manual suggested but nothing works. I also tried filling the resevoir to the recomended hight.
Can anyone tell me what to do about the center lift or trim and what to do about the outers?
-Shawn-
RRitt
Re: Another trim tilt issue
not enough information. most common causes of no lift is broken motor, blown out manual release valve, or split piston ring on trim.
