I know -I know, but this one is weird. I had to bleed off the fluid one day at the lake (line leaking and replaced). Any ways, I rederviced the trim motor, got enough in there to get it going. Then after a couple of times of running it, it only will click once and then nothing. The fluid is almost to the top and th CB is in. When I play with the plugs i will get one click at the solenoid and then nothing. Should I add more fluid, tap on it? any help or reassurance will be helpful.
