Another: Which Spark Plug Thread
jeepnsam
1995 Searay
Merc 5.0 v8 305 CID
Alpha I Gen II
The owners manual says to use:
AC-MR43T
Champion RV8C
The air cleaner cover says to use:
AC-MR44T
I pulled out:
Champion RV8C
When I pulled one out:
* ceramic insulator broke in half
* electrode was black and sooty looking
I've read the AC-MR43T is the cold plug and the AC-MR44T is the hotter plug.
Which one would you recommend based on the above analysis??
Thanks,
Sam
Re: Another: Which Spark Plug Thread
Ayuh,... The AC Delco MR43T,.... Then fix the Carb...
jeepnsam
> AC-MR43T
> Champion RV8C
> I pulled out:
> Champion RV8C
I did a cross reference and the RV8C is not a Marine Rated plug so why would the manufacturer suggest a non-marine plug as an alternate to the MR43T??
An why would the air cleaner cover state to use the MR44T which is the hotter plug??
I'm thinking the owners manual is the "best practice" guide and the Air Cleaner is the "use this one" guide? What's your opinion?
YES the carb seams a bit rich, so I'll have that taken car of also...just want to get the correct plugs in there since the RV8C's I pulled out crumbled.
Thanks,
Sam
JustJason
Actually the best practice is to follow....
1. The Dealer parts listing and/or any TSB's regarding that motor.
2. The factory service manual
Unless your the original owner it may not have the correct plastic up top.
Pretty much universally, those motors all run AC MR43T's. They also will run an NGK equivelent. If you ask most mechanics they will tell you champions are lousy. I'm a mechanic and i'll tell you champions are lousy.
You'd only want to run MR44s in that motor if you were running in cold weather all the time in a lightly loaded boat.
zbnutcase
Champions are lousy! NGK is what I use.
jeepnsam
More information for the Forums:
The higher the number, the hotter the plug on AC Delco Plugs:
M = marine
R = resistor
4 = 14mm thread
3 = heat range
T = tapered seat shell design
However the cross references are not always in the same heat range
as the manufactures recommended plugs (MR43T).
http://www.sparkplugs.com/results_cross.asp?pid=MR43T&x=0&y=0&seenCrossWarning=1
CONCLUSION:
I'll stick with AC MR43T's.
Thanks,
Sam
jeepnsam
UPDATE:
> AC-MR43T
> Champion RV8C
> I pulled out:
> Champion RV8C
Now here's the comparison between a new AC-MR43T picked up from NAPA today and the old broken Champion RV8C. What a major difference in length.
Blurry Pic :(
http://i133.photobucket.com/albums/q75/jeep_n_sam/IMAG0083.jpg
Don S
Here is from the OEM service manual The blue dotted line indicates a change from a parts bulletin.
attachment.php
gjcombs
moved to new thread....
