lonewolf41
- Jun 28, 2013
- 143
Bought a 5.0OSi-E (model 3869270, serial 4012110198) to re-power my boat. Wanted to start it up before installing to make sure it runs OK, etc. It would barely start and then die. Began to hear a whining from the fuel pump. Went out a hour later to try again with pressure tester connected to the fuel rail. This time it started up and ran well. Fuel pressure was around 60 psi. After a couple minutes, the pump started whining and the pressure began dropping until it got to around 15 psi and the engine died. The pump was hot to the touch. I know there are multiple posts on here about similar issues so I took off the high pressure pump and the screen had maybe 8-10 small particles in it, but it was not clogged by any means.
I had another high pressure fuel pump from another motor (the one I am replacing) so I put it on there and the pressure with this pump would run about 80-85 psi and then it started to whine, loose pressure, etc after a pretty short time. It was also hot to the touch. One other side note...with the original pump, the pressure would drop to 0 after the motor stopped. The "new" pump would maintain pressure after the motor was shut off.
So my question is will replacing the high pressure pump fix this or is there some other underlying cause causing the pump to act this way? I.E is the pump getting hot causing it to fail (poor cooling), or is because the pump is failing, it is getting hot. Neither pump was plugged, but both got hot. Both pumps were used. I think the one that came with the motor had a little over 100 hours on it. Not sure about the one that came with the boat. I just don't want to start throwing parts at it.
TIA,
-Keith
TIA,
-Keith
