Re: Antenna splitter?
A splitter can carry any frequency to which it's tuned. Like in TV you have VHF off your antenna at 200 MHz and UHF at 300 MHz, sometimes you get FM off the same antenna at 88 Mhz, all of which come down a single coax from a splitter (combiner....splitter hooked up backwards) that can accommodate the bandwidth of all 3 signals.
Usually you will loose 3db of power (that's half) because the other half goes out to the split circuit.
Impedance matching is critical for optimum signal transfer so splitters are designed to make the generator/receiver think it still sees one matched load even though it now sees two.
Radio's (most all radio wave devices) have an automatic gain control circuit which is in operation on most signals except for the weakest. Unless your normal communications are from great distances, you probably won't know that your signal is half as big as it was before acquiring the splitter.....kind of like running your depth sounder at 20' when you know it's good for 300.
Try it, you can always take it out.
Mark
