Anti-Fouling Paint Removal
Panamapty
Dear Sirs:<br />Could anyone give me a good advice on how removing antifouling paint from my dusky 25.6. Any special product that can help me remove it or any technique..<br />I will really appreciate it<br /><br />Thanks a Lot
Oldsaltydog
Re: Anti-Fouling Paint Removal
Welcome to the Iboats Forum!<br /><br />If the barnacles are all scraped off, people around here continue with a pressure washer (be careful, a narrow stream can puncture a hull) and a circular power sander.
AndyL
There is a trend here to shot blast it off. Very efficient as long as the operator is competent. I believe they use soft beads that is so precise it can remove individual layers of paint without damaging the gel. Relatively expensive but very efficient and leaves the surface well keyed ready to apply new coating. Will save your hours of work and heaps of antifoul paint remover.
crazy charlie
Peel away chemical stripper works the best with the least effort.Charlie
18rabbit
Something to keep in mind... Only in the last couple of years was the chemical TBT banned from use in bottom paints in the US. The best bottom paints have this microbe growth inhibitor in them. Ocean critters don’t want anything to do with it either. TBT is extremely toxic. You don’t want to play around in the vapors of that stuff. If you use heat or chemical stripper on old bottom paint (more than 2 or 3 years old) you should do so only with full breathing/respirator protection. I would use mechanical means to remove.<br /><br />Bottom paints with TBT are still made in the US but cannot be sold here. They are shipped out for use everywhere else in the world. TBT is still ok to use in paints that are applied to bathroom and/or steam house walls…anywhere high humidity will allow fungus growth. $15 will get you a little bottle of TBT anywhere paint is sold. Enough to mix in with 5-gals of paint. I know of a couple sailboats in the SF bay that have not been hauled out in 5+ years and there is still nothing growing on the hulls. The theory being if a little TBT will inhibit a little growth, a lot of TBT will inhibit a lot of growth…<br /><br />Recently saw a documentary on the recovery of the lost space capsule … the one that sunk in the late 60’s/early 70’s. My first thought when I saw the remote video of the capsule as it sat on the ocean floor for 30-years was “no growth on it!!! … Nothing!!!” Some growth on exposed steel parts but nothing on any painted part. Whatever it is that NASA uses to paint their space vehicles with, I want to use on the bottom of my boat!
crazy charlie
NASA does not paint space capsules you screwy Rabbit!!!! They use heat shield ceramic.There is no paint in the world that would stand up to the heat of space travel.Screwy Wabbit..... Charlie
AndyL
Truth of the matter is that it was inhabited by a very house proud capsule shaped hermit crab that just enjoyed keeping up appearances on the ocean floor, :) <br />I fully agree with 18rabbit on the toxicity issue though. Certainly woth taking precautions from inhaling any of the dust from the removal process. It was claimed that drinking a pint of milk put a protective lining on the stomach when applying the antifoul as it can make you feel ill.
18rabbit
Things To Do List: ITEM 729448 – research heat shield ceramic for vessel hull.<br /><br />Thanks, Charlie!!! :)
