Anti seize For lower unit drain bolt
Marble13
Hey guys I was changing the lower gear oil on my SX drive and was curious if you guys suggest putting marine grade anti seize on the bolt or if that’s not recommended?
alldodge
I wouldn't, it will be removed every year or at least every other year
ChrisCraftFan
I would however, recommend a new o-ring each time. I order them 3 at a time so I have them on hand.
BRICH1260
I coat the threads liberally with OMC triple guard grease when putting mine back in for the season. figuring it might prevent seizing and give a little bit of sealing between the water and oil.
The thread will be exposed to oil.----I see no need to add any potions.
dingbat
And if you haven’t done so already, swap out the OE drain plug for one that requires a hex key, aka Allen wrench to remove
