Anti-Seize ?'s
Re: Anti-Seize ?'s
Well,.... Don calls it Alwaysieze...
I've been Slathering it on anything,+ everything I plan to take apart someday for about 40 years now,...
Without problems...
Now,... I don't boat in Saltwater, but the equipment I work on runs some mighty salty roads...
JUSTINTIME
Re: Anti-Seize ?'s
the copper one or the nickel one?
i just did a ABYC class and they said stay away with anything with copper
we leaned this in tech class also
Re: Anti-Seize ?'s
Ayuh,... The 1 you linked to...
JUSTINTIME
Re: Anti-Seize ?'s
OK
it has copper, but your in fresh
i think salt water has got to be the reason why they say no
Don S
Re: Anti-Seize ?'s
Nope, I call it "Eversieze"
Show me an OEM service manual from anyone that says to use it anywhere on the outdrive, transom shield or anything that gets contact with raw water.
You may find it suggested on some aftermarket manuals but not OEM.
Why, because there are better more approprite products to use in place of eversieze. All that stuff does is makes a mess and makes the DIYer happy. Copper keeps the barnicals off, but doesn't stop corrosion when near aluminum or other metals. Then it's called a battery. the products with zink in them.......... well, they become an anode. Go figure.
On engines, a bit of perfect seal/aviation gasket sealer on bolts prevents corrosion and doesn't make a mess.
Of course, this is just my humble opinion :)
JUSTINTIME
Re: Anti-Seize ?'s
but copper and aluminium are a no-no in marine environment right?
hence that is why your supposed to paint up to 1" from drive?
JUSTINTIME
Re: Anti-Seize ?'s
I'm just trying to get more info on it here, so i can tell that wake dude he has to stop smokin!
I tried to contact a marine surveyor, but he blew me off!
Don S
Re: Anti-Seize ?'s
Thus the comment:
Copper bottom paint should not be on outdrives or transom shields. Thus the 1" rule for copper bottom paint.
JUSTINTIME
Re: Anti-Seize ?'s
my point was like DON S said
copper and aluminium will make a battery!!!
Re: Anti-Seize ?'s
Ayuh,... That's it,... didn't think it looked right when I pecked it out,...:redface:
JUSTINTIME
Re: Anti-Seize ?'s
I hate to aruge when im right, LOL
Oh well some poeple will never learn
there is always 2 ways of doing it
your way, or the right way
Fun Times
Re: Anti-Seize ?'s
:D
:D
Just make sure he has your info for when he is ready to have it done right the next time.:p
JustJason
Re: Anti-Seize ?'s
Yep... 2 dissimilar metals + an electrolyte (saltwater) makes a battery. 1 metal will be the annode, and accept free electrons, the other metal will be a cathode, and give up free electrons.
The real fun begins when you start mixing lots of metals. The everseize is 1 metal, the aluminum drive is a 2nd, the studs are steel, there's a 3rd metal. If the locknut is a different alloy than the stud, there's a 4th metal.
That's why for threads in saltwater, treating them with a non-metalic sealer (perfectseal) is prefered. Now if your talking trailer lugnuts, I still use marine nickel based eversieze on the studs. There is still an electrical potential difference because the stuff is nickle based and the steel is a dissimilar metal, but the anode/cathode ratings on both metals is so close the result is negligable.
2 good quick reads...
http://www.auf.asn.au/scratchbuilder/corrosion.html
http://www.boatus.com/boattech/MarineCorrosion.htm
Hey Justintime.... weren't we supposed to work out something with swapping service manuals a while back?? :)
JustJason
Re: Anti-Seize ?'s
Whoah.... Not to many moderators over at that other site eh? Justin, i'm not sure if I have your email saved in mine anymore. Please PM it to me when you get a chance.
JUSTINTIME
Re: Anti-Seize ?'s
PM sent
yep typical wakeboat owner
more $$$ then brains
post over there, straighten these guys out!!
I get emails daily from these wakeboat guys and get thanks all the time
I have a SPARKY used to work for my old company, LOL
dan t.
Re: Anti-Seize ?'s
the best antisieze is plain old grease, I found this out the hard way when the former owner of a boat I bought used basic neversieze on the prop shaft. I got it off 3 hours and much profanity later. Even on brake hardware a good synthetic grease will out last antisieze compound
