anti siphon valve
cooter2506
I traced my fuel line from the seperator canister to the tank and on the tank there is a 3/8 hose barb fitting. Removed the fitting and found a check ball inside. Is this my anti siphon valve? I pushed ion the ball with a small flat screwdriver and had to all but break it free. I had only 3800 rpm on tach before. So I was diagnosing it. if this is not my anti siphon valve the what is it and could it be a low rpm problem?
Don S
Re: anti siphon valve
Yep, it's the anti siphon valve. If it's sticking, replace it, they are very inexpensive.
cooter2506
thanks Don you are the man. How is life in the new home? can they be picked up a napa store or are they marine specific?
180shabah
Cars don't use them, but NAPA does carry Sierra marine parts. should be ten bucks or so.
