Just pulled off the exhaust manifolds and discovered antifreeze in the manifold exhaust section and in the exhaust ports of the engine block.
I have tested the exhaust manifolds and there are no leaks. Liquid cooled closed system. No sea water.
Is this a sign of a blown head gasket? Will a simple compression test show if there is head gasket leak to the exhaust?
2009. 5.7 liter mpi. Closed cooling circuit.
