capnchaplin
- Aug 20, 2003
- 3
whats the best way to get the antifreeze out after winterizing
That is a great idea if you did use eth glycol. It wouldn't get 100%, but most of it. I use Prestone low-tox, a poly glycol with anti-corrosion. Sierra is another brand of poly gly.Originally posted by jlshields:<br />Make sure your bilge plug is in, pull the engine and manifold drain plugs and the water pump hose and let it drain into the bilge then pull the bilge plug and let that drain into a drain pan.
