powerboat22
- Apr 17, 2004
- 4
Mercruiser 190, 470, 224 cui 1986 engine 3.7 L
I replaced the riser with brand new, gasket and all, torque 55 ft/lb. The manifold is good, dry. No antifreeze in the oil.
The heat exchanger is tested good, no holes.
When refilling with antifreeze, when it is filling the riser reservoir, it runs through the exhaust hole on the starboard side and through the water intakes holes of the leg??? The level stays with the top of the exhaust manifold.
Any ideas? or at least I need a drawing or something to figure it out.
Thank you.
Steve.
Thank you.
Steve.
